Re: TDC the measuring of.
Posted: Sat Sep 28, 2013 8:15 pm
Isn't that effectively TDC?jason frost wrote:You dont find TDC, you just find when the piston stops moving, then set it to 0, easy
It's not exactly TDC because of the dwell, but it is the at the top of piston travel.DigDug wrote:Isn't that effectively TDC?
dirtyhandslopez wrote:That's all well and good Firedkp, provided that the con rod is exactly what it is suppose to be. With manufacturing tolerances being what they are, that isn't always the case, ie a 107mm con rod may not be exactly 107mm, 58mm stroke may not be exactly 58mm, so that would throw the whole equation out the window.
If using a dialguage and holding bracket isn't the best, easiest way, why did Innocenti proved two different size holding brackets(one 150's, one for 200's) to dealers? You'd think the manufactures would know what they were doing.
If you watch the dial closely when going to and past tdc, the dwell really isn't all that much to worry about in real world applications.
I don't know what tolerances they are made to, but I've always thought they were precision engineered. If the rod/stroke are miles out, then what's the rest of it like? However, using the piston travel vs crank rotation in Sticky's, look what difference a 110mm vs 107mm rod makes to piston travel at 19 degrees, 0.01mm. So a rod 3mm longer and massively out of tolerance would only give a discrepancy of a fraction of a degree. With parallex error etc, you're probably going to get more discrepancy than that making the mark on mag housing.dirtyhandslopez wrote:That's all well and good Firedkp, provided that the con rod is exactly what it is suppose to be. With manufacturing tolerances being what they are, that isn't always the case, ie a 107mm con rod may not be exactly 107mm, 58mm stroke may not be exactly 58mm, so that would throw the whole equation out the window.
dirtyhandslopez wrote:If using a dialguage and holding bracket isn't the best, easiest way, why did Innocenti proved two different size holding brackets(one 150's, one for 200's) to dealers? You'd think the manufactures would know what they were doing.
Againdirtyhandslopez wrote:If you watch the dial closely when going to and past tdc, the dwell really isn't all that much to worry about in real world applications.
I think you need to re-read my postsdirtyhandslopez wrote:
From what I can gather, you are saying there is no such thing as tdc becuause of the dwell factor and that using the trigonometry equation is the best way to go about it.
And all calculated for you by clever b*st*rds using trigonometrydirtyhandslopez wrote:The easiest way to know what measurement relates to what con/stroke etc is to look it up in the Sip Lambretta parts book or Sticky's![]()
(if you have a copy, which I don't) .
What confused me was, in your first post you said, tolerances in rod/stroke length would make the dial gauge process inaccurate, but then went on to say that, Innocenti deemed it the best, and that you used the method yourself. Totally contradictory.dirtyhandslopez wrote:So we are on the same page. Roughly.
