RB250 SCOOTER SHOOTOUT MOTOR
Post your Lambretta dyno graphs here! But graphs & spec info only, keep the chat in the 'dyno chat' section ;o)
Eibar
Main scooter: Eibar TS1 1966
45 amazing .
Does the dyno have its SAE correction factor turned on
potato
Darrell Taylor
Main scooter: LAMBRETTA
Eibar wrote:45 amazing .
yes turned on if you check all my graphs at the bottom right youll see the correction factor type saej1439 (equivalent to dynojet) and the automatic barometric adjustment which was quite a lot yesterday at 0.946 therefore making the power figure lower
if you see one with 1.00 its uncorrected
just checked for you and uncorrected is 48.13 bhp
"std no welding crankcases matched to cylinder", not even for stroke increase and central trench?
Adam
Darrell Taylor
your right adam it is machined a little for clearance ill edit that part(the case was already done so not a job on my list hence i forgot)
although my referance was to no welding / std
Welded and machined or just machined? I ask as I've got various machined and welded + machined cases and various modified big-end rods to fit accordingly. I guess that guessing the balance right is the issue here so I'm always interested to hear/know what others are doing.
Thanks for the info, on what seems like an amazing motor :)
Adam
Darrell Taylor
just machined it uses the pm conrod 116mm that has a very slim profile ,i believe its same as jb crank so eden has the same i think
Cool, thanks.
Funnily enough, that's exactly the rod/crank that I recently bought, along with Muggy piston with the intention of putting together a 62mm stroke Avanti TT3 :)
Adam
Darrell Taylor
worth checking the big end clearance,the ones ive had are too tight 0.2mm
Side float?
Phenominal result.....would you hazard a guess that it is now peaking somewhere around 9500rpm??
    Users browsing this forum: No registered users and 57 guests
