MB digital speedo ( again )
iang
Main scooter: GP-auto / gts 250
mark wrote:what size is that speedo and is it waterproof?
The one i ordered is 3 3/8 inches.They do do a 4 inch version.I also spoke to them re fitting to bike/scoot and they said it would be fine as they are waterproof..
iang
coaster wrote:2 potential problems with GPS speedos would be that the Lammy headset is made of metal which will probably affect the signal and the other problem would be that your speedo will die whenever the GPS sugnal is lost, i.e. in tunnels. Haaving said that, I live with the 2nd problem already with the Garmin forrunner I'm currently using as
well as the time it sometimes takes to find a signal.
My tom tom satnav speedo has always worked fine even going through small tunnels and yes it would die if the tunnel was really long but then i can't remember the last long tunnel i went through on my scoot..and all this is bearing in mind that my sat nav is working in a mobile tin can !!!
iang wrote:My tom tom satnav speedo has always worked fine even going through small tunnels and yes it would die if the tunnel was really long but then i can't remember the last long tunnel i went through on my
I also use a TomTom on my GTS and it loses the signal in all 3 of the Thames tunnels as well as the Limehouse Link (approx 1/2 mile) which has speed cameras in :evil:
iang wrote:all this is bearing in mind that my sat nav is working in a mobile tin can !!!
Of course your satnav will work in your tin box car, it has windows, in fact some won't work with heated windscreens and have to use an arial. The GPS speedo MIGHT have taken this into account and put the antena behind the speedo face?
a lot of satnav's wont work in an airconditioned car because of the reflective coating on the laminate plastic sheet between glass , this is why citreon ,renault and peugout leave a small satnav sized area clear in the lower part of windscreen in line with middle of dashboard
iang
Arghhh..joys of living in london ;) ..I feel deprived....unfortunately I live in hampshire and long tunnells are few and far between :cry:
iang
I'm just lucky then..I've never had a problem with mine bearing in mind i got a billy basic astra van.. heated screen, air con...whats that ??????.
well i'll have to see how i get on.The gps speedo does not have a inbuilt antenna it's on a cable so you can mount it where you like...so i'll have to experiment
