slangen
Main scooter: TV200
Had the same thing in my ts1 Dl200 engine. Click click but not any rubbing like you say. It was the gearbox shim that was moving around. Do you get the same sound with the crank case cover facing up?
fastfrog
What do you mean by "crankcase cover facing up"?
Size matters!
slangen
Main scooter: TV200
Sorry engine case cover.
Gear box Shim to thin rattling/moving around. I moved up .2mm and it disappeared.
fastfrog
+1 I need to open my case cover and see where it comes from.
Shim? Yeap! maybe,
or a gear fits upside down...
Size matters!
eden
do you have oil in the gearbox yet? could just been the chain catching the sprocket.
fastfrog
no oil yet.
Size matters!
eden
put some in and see if the sound goes away :p
fastfrog
did it, no change. noise is as if a leaf was touching bicycle spokes.... French mates told me it sounded like a gear set the wrong way...
Size matters!
camel
ive never known a lambretta not to make a click...I personally wouldn't worry about it
fastfrog
read it also on several posts....
It takes max 1h to split cases and disassemble gearbox. I can't sleep like a baby without checking if anything wrong inside.
I keep you posted.
By the way I'm interested in a new clutch but aint got much experience in clutch business: Is this one a good one?
http://beedspeed.com/lambretta-clutch-c ... -8918.html
Size matters!
