Aprillia RS125 smallie engine
Wayne Miller
tony wrote:I know Wayne there was a little more involved than just that with your crank. From the bearing type-its tolerances.. to pin tolerances ...to the re assembly process.. its really not that simple.
Ey up Tony, where have you been hiding ?
You going to Mallory practice day? If so I'll come over and see/watch you on the green hornet :-)
The crank really was'nt that hard to do? Im sure when charlie split the crank he used his own pin, my bearings and a couple of standard mazz shims? He didnt use anything else apart from his skill and 7 tonnes of pressure to press it :-)
Mind you saying that I guess if some one wants one doing then charlies the man to see ;-)
PS get back on the smallframe forum ya mad man !!!!!!!!
Stay tuned..............
C*NTSPEED
Wayne Miller wrote:
C*NTSPEED wrote:where are we up to on this wayne?????
Its finished mate, I had it done by mid november. The only prob was that we got hit by the bad weather, I stuck the scooter under three waterproof layers and left it in my shed. I pulled it out a couple of weeks ago to stick some juice in and take it for a blast when I realised that I hadnt drained the system correctly and Id left some water in the cylinder. I hadnt even used antifreeze just plain old water. Obviously one of the cylinders that Mick tuned for me has now split. I have another tuned cylinder and a standard one to play with so Im going to stick the standard one on for now as I havent ridden it with this cylinder on and I want to know how it goes before swapping back to the other tuned cylinder that Mick did. Im working this weekend but I should have time the following weekend to sort it out. I'll take it for a blast and take a few pics/video ;-)
ps this is my last recorded top speed . . . . 73.1mph
sounds impressive carnt wait for the final outcome
Not bad for a 125cc with a rubbing rear tyre and the powervalve fully closed.
I'll max it out next weekend and see what the real top speed is :-)
pps it gets there quite quick too :baddevil:
GEMINI S.C.
BLACK WIDDA'S S.C.
Wayne Miller
My smallies been moth balled all winter or should i say ice cubed as when I uncovered the little beastie the cylinder had split (Id left a little bit of water in ther but enough to split the cylinder) Anyhow Ive had to fit the standard cylinder back on and its nearly ready to rumble again. Ive just got to fit the carb, powervale cable and hoses tomorrow, sort the rear tyre out and then off to santa pod it is :-) sh177ing myself about it but cant fooking wait :twisted: :twisted: :twisted: :twisted: :twisted:
:shock: Awesome :D
twin peeks
Main scooter: gp200 ts1
hello ,saw this scoot at the wickstead today ,looks the nuts ,wear did you get your rads from
saw it also and hoping to get to santa pod on sat but will def be there sun
Wayne Miller
twin peeks wrote:hello ,saw this scoot at the wickstead today ,looks the nuts ,wear did you get your rads from
Cheers mate, got the radiators years back for a lammy cutdown project that never got finished.
I got them off Ebay, cant remember where but heres some that are similar
Wayne Miller
mark wrote:saw it also and hoping to get to santa pod on sat but will def be there sun
Im only there on Saturday so come say hello if you make it ;)
The Mrs has something else planned on Sunday so I wont be there for Straightliners :evil:
twin peeks
thanks for info on the rads,hoping to be at santa pod on saterday with my gp ts1,how much to run the bike :D :roll:
Wayne Miller
twin peeks wrote:thanks for info on the rads,hoping to be at santa pod on saterday with my gp ts1,how much to run the bike :D :roll:
£10 to get in and watch and then a further £25 to run up the strip
