Page 11 of 22
Re: 12V DC CONVERSION - HOW TO
Posted: Thu Feb 23, 2012 10:37 pm
by mac
Advise please, I've converted a stator to DC and fitted the unit etc and having a couple of probs!
What voltage should be coming from each of the yellows and should they be the same or is it variable
Posted: Thu Feb 23, 2012 10:39 pm
by mark
What problems?
What voltage you got from the red out of wassel?
What stator?
Posted: Thu Feb 23, 2012 10:55 pm
by mac
On the red I've got 4 volts DC on tickover and 3 volts when the rev's rise if I connect it to the loom it rises to around 6 volts.
On one yellow I've got around 15 volts AC and the other about 5 volts AC
Forgot to add SIL stator
Posted: Thu Feb 23, 2012 10:58 pm
by mark
That's odd. You got a pic of stator. Run a continuity test between the yellows of stator and the stator plate mounting plate
Posted: Thu Feb 23, 2012 11:11 pm
by mac
Very odd, prob not going to able to look at it until Saturday, so just wanted to get a few ideas to check out before I start replacing things
Posted: Thu Feb 23, 2012 11:13 pm
by mark
To me it seems as if you have a bad connection on the new yellow even possibly still earthing
Posted: Thu Feb 23, 2012 11:23 pm
by mac
Cheers I'll test it and rewire, I've got another one already converted that I can swap it with and another regulator
Posted: Thu Feb 23, 2012 11:30 pm
by coaster
Edited, oops, didn't look far enough down the page, mark has covered all the likely issues, it's easy to nip the extra wire when bolting the stator down.
Posted: Thu Feb 23, 2012 11:43 pm
by mac
It'll teach me right for putting the rear footboard back on before I tested the output with a meter
Posted: Fri Feb 24, 2012 9:59 am
by firekdp
mac wrote:On the red I've got 4 volts DC on tickover and 3 volts when the rev's rise if I connect it to the loom it rises to around 6 volts.
You will need a battery or capacitor connected to the reg/rec to get it to function correctly and get a decent voltage out of it.
The AC reading should be taken from between the yellows, not from each yellow to earth. In fact, with the yellows disconnected from the reg/rec there should be no voltage between them and earth (although the meter may read a very small voltage).
