TS1 clutch springs
cable routing or not using a nylon lined cable or uneven height springs
celt
joeythescooterboy wrote:
celt wrote: any ideas :?:
Yes Richie lad, get yourself a Vespa!!Image
Over my dead body Joey :P
mark wrote:cable routing or not using a nylon lined cable or uneven height springs
Cable is routed correctly and using a nylon line cable. As I said before springs are the same hight and ground on either end. Thanks for the input though
Diablo wrote:A set up that I've used with success is to use uprated springs with std Vespa springs over the top. This gives extra spring pressure but with a useable lever.
This is probably your best option without looking at 5/6 plate options. Are the steels still flat if laid on a piece of glass?
celt
[/quote]
This is probably your best option without looking at 5/6 plate options. Are the steels still flat if laid on a piece of glass?[/quote]
Good question, I didn't think of that :| If I have to take apart again I will try that ;)
