cylinder cowling "fin" welding needed
J1MS wrote:The Indian head cowl seems to have a good shape cut into it for directing the air below the footboard, instead of directing it back under the panels, but they used very thin metal on some of them...
A spot welder would be the best way to weld the fin into place, very easy to use, just set the timer and press together...
Add to wish list, A 230 volt hand held Spot Welder.. :)
i,ll be using a TIG AS MY MIG IS KAPUT
Hmmm, all the carbon cowls have no lip on the L shape cut out :-?
Is a cowl with the scoop a preferred choice or not?
And what about cutaway or removed footboards, help or hindrance?
May have to send one down Steve ;-)
May have asked before, but what happened to the MB ones?
cezeta
what are you after a template of the fin? i have a spanish cowling with the fin inside. is this whats needed?
J1MS
Ian, PM sent...
soullad
J1MS wrote:Ian, PM sent...
cheers.
