Tino saachi belt drive system.
J1MS
That looks very well made, Tino Saachi does seem to have an ability to produce what others would struggle to just imagine...
The adjuster does look very much like a modified version that Charlie Emdunds currently uses on his group 4 race scooter with two bearings and a neatly machined nylon roller adjusting the chain inwards (on Charlies) instead of pushing outwards as on standards scooters to remove slack.
Just maybe, Charlie might have had a look at this while it was in the design stage :?:
damdam
I got a flyer of that kit I took directly from Tino Sacchi, who I met on a scooter custom show 2 weeks ago here in Italy (Tino was also showing the kit itself)
I can try to scan it
6LDA 28B wrote:I had a ktm with a 560cc rotax engine it had a cam belt that would run problem free as long as the pulley wheels were fitted correctly just a few mm out and it would shred the belt in minutes.
Could the Tino have a dry clutch and a sealed gearbox end plate
You need a hole in the end plate for the kickstart
