Finless Flywheel
paulmgreen
so are you going for scoop cooling or watercooling?
www.JPPLambretta.co.uk
J1MS
paulmgreen wrote:so are you going for scoop cooling or watercooling?
If you were going to ditch the fan and just run a scoop, Would you change the head for one with a better designed cooling fin (Like the Villiers head) to go with the scoop, or do you think the standard type head fitted with a scoop would cool well enough..??
Bilko
Main scooter: LI150
Water cooling
Bilko's Oily Blog
Bilko wrote:Hello Coaster, no it's not for a fan, there will be no fan. But am I right in thinking from your reply that without the fins and fin housing, it doesn't protrude from the mag housing?
Sorry Bilco, I don't know the answer, I was just guessing as to why you wanted know and 2nd guessing a fix :?
Bilko
Main scooter: LI150
No worries old bean. :)
Bilko's Oily Blog
hi bilko.........
hope this helps you....... :D
measurements are for indian type flywheel with alloy fins removed ........GP
height above inner lip..........approx 9.3mm..........
height above outer lip...(where tdc mark is)...........5.3mm approx.......
height to the base between the two lips..........16.38mm approx.........
Bilko
Main scooter: LI150
Bilko takes note of the post by Sean of Sean Brady's Scooters. He moves to the drawing room and takes out his abacus and studies the figures laid out in front of him..
Bilko's Oily Blog
Bilko wrote:Bilko takes note of the post by Sean of Sean Brady's Scooters. He moves to the drawing room and takes out his abacus and studies the figures laid out in front of him..
Bilko's head hurts, so he has another pint of Guinness and goes to bed. :P
