Finless Flywheel
- paulmgreen
- Main scooter: Lambretta Group 4 Race 200
so are you going for scoop cooling or watercooling?
www.JPPLambretta.co.uk
If you were going to ditch the fan and just run a scoop, Would you change the head for one with a better designed cooling fin (Like the Villiers head) to go with the scoop, or do you think the standard type head fitted with a scoop would cool well enough..??paulmgreen wrote:so are you going for scoop cooling or watercooling?
- coaster
Sorry Bilco, I don't know the answer, I was just guessing as to why you wanted know and 2nd guessing a fixBilko wrote:Hello Coaster, no it's not for a fan, there will be no fan. But am I right in thinking from your reply that without the fins and fin housing, it doesn't protrude from the mag housing?
- sean brady scooters
- Dealer
hi bilko.........
hope this helps you.......
measurements are for indian type flywheel with alloy fins removed ........GP
height above inner lip..........approx 9.3mm..........
height above outer lip...(where tdc mark is)...........5.3mm approx.......
height to the base between the two lips..........16.38mm approx.........
- corrado
- Dealer
- Main scooter: Lambretta GP
Bilko's head hurts, so he has another pint of Guinness and goes to bed.Bilko wrote:Bilko takes note of the post by Sean of Sean Brady's Scooters. He moves to the drawing room and takes out his abacus and studies the figures laid out in front of him..
