Tubeless rims, rubber type valve: WARNING...
soosh
They are deff. tubeless.Seems they are a bit of a b@5t@rd to fit though.
soosh
red wrote:
soosh wrote:Has anyone started using these split tubless rims from Patron racing in Doncaster.Im interested in them and gonna be buying some soon but wondered if anyone else has clocked up any miles on them? At least they are UK based and they seem a decent company who give a s**t unlike some others.
I've used these for about 3-4000 miles now and haven't found any problems apart from refitting tyres.I've ended up taking them back so that Pat can fit them.
Here's the link for his shop.
http://www.lambrettarestore.com/
What was the issue in fitting them? You rekon its not possible to do at home?
They are the type that MB embarked on a few years ago and decided not to persue :|
Metal-Guru
Just had a look at the Demon Tweeks Bike It valves
£4.58 each for right angle ones
They do look identical to the ones im my Scootrs v3 rims
I presume it is the grade of the rubber grommet that is the difference??
Am i correct in this - that the failure part is possibly with the softness grade of the rubber grommet?
Looks like i will be ringing them soon !!
red
corrado wrote:So are these rims definitely tubeless....
http://www.lambrettarestore.com/alloy-w ... 1586-p.asp
It just says alloy, mentions the bead but doesn't say that they're tubeless????
Yes,definitely tubeless.
Nic
Metal-Guru wrote:Just had a look at the Demon Tweeks Bike It valves
The rubber on my ScootRS valves felt "softer" and more pliable than the Demon Tweeks ones that replaced them. That may be just my imagination and I don't know about the grade or quality of the rubber used but I don't think so.
It's be worth hearing again from those whose valves went to see what they think.
jimmers
anyone got a link for the correct valves to buy please?
mac
Here's a link to the Bike it site showing the valve and order code
http://www.bikeit.co.uk/tyres_product.asp?ID=16
soosh
soulsurfer wrote:They are the type that MB embarked on a few years ago and decided not to persue :|
Spoke with them and they said MB had nothing to do with the design of these and they did it all themselves which they are gonna say but they use them on their road bikes aswell.
