Cylinder head refitting
EddieStone
Traditionally lapping involves a thick sheet of glass with a sheet of wet & dry paper on top (mum's coffee table when she was out) and twist the head on the paper until it's a uniform grey colour. Doesn't take long, and I usually do it every time I replace the head to make sure it's not warped at all.
To do it to the barrel means the engine has to be dropped.
Davidsquaredson
You want the sanding surface to be perfectly flat. A simple solution is a piece of window glass or go to a local charity shop and buy a mirror. You can get spray adhesive at a hardware or craft store to attach the sand paper to the glass. . Use 320 grit sand paper or finer. Use irregular motion or a figure 8. Periodically check. Stop when you see the surface a common colour.
Sent from my SM-G928W8 using Tapatalk
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
Scooterdude
Sent from my iPad using Tapatalk
garry inglis
nice one
mr mugello wrote:Not 100%sure head is even blowing. Might just Lapp the head. Looking like it's a engine drop to remove barrel I take ?
If you remove the rear shock and the rubber bump stop the barrel should come off the studs ok with out dropping the engine.
mr mugello
Handy to know . Is this on a 200 block and barrel ?
mr mugello
Does the head gasket need to be coated both sides if using a sealer such like wellseal ?
Scooterdude
mr mugello wrote:Does the head gasket need to be coated both sides if using a sealer such like wellseal ?
if your using a gasket you shouldn't need any sealant. If your not using a gasket put a smear on both surfaces and wait a minute or so for it to go tacky then slap um together..
I'd aim to not use a gasket if clearance allows it as your gasket will always be the weak link.
Sorry about the Jim Royal thing but I just couldn't help myself haha.
dazblakey
Is Cork best
EddieStone
dazblakey wrote:Is Cork best
No.
