Cylinder head refitting
EddieStone
Traditionally lapping involves a thick sheet of glass with a sheet of wet & dry paper on top (mum's coffee table when she was out) and twist the head on the paper until it's a uniform grey colour. Doesn't take long, and I usually do it every time I replace the head to make sure it's not warped at all.
To do it to the barrel means the engine has to be dropped.
Davidsquaredson
Main scooter: Early Eibar Jet 200
You want the sanding surface to be perfectly flat. A simple solution is a piece of window glass or go to a local charity shop and buy a mirror. You can get spray adhesive at a hardware or craft store to attach the sand paper to the glass. . Use 320 grit sand paper or finer. Use irregular motion or a figure 8. Periodically check. Stop when you see the surface a common colour.
Sent from my SM-G928W8 using Tapatalk
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
Scooterdude
garry inglis
nice one
mr mugello wrote:Not 100%sure head is even blowing. Might just Lapp the head. Looking like it's a engine drop to remove barrel I take ?
If you remove the rear shock and the rubber bump stop the barrel should come off the studs ok with out dropping the engine.
mr mugello
Handy to know . Is this on a 200 block and barrel ?
mr mugello
Does the head gasket need to be coated both sides if using a sealer such like wellseal ?
Scooterdude
mr mugello wrote:Does the head gasket need to be coated both sides if using a sealer such like wellseal ?
if your using a gasket you shouldn't need any sealant. If your not using a gasket put a smear on both surfaces and wait a minute or so for it to go tacky then slap um together..
I'd aim to not use a gasket if clearance allows it as your gasket will always be the weak link.
Sorry about the Jim Royal thing but I just couldn't help myself haha.
dazblakey
Is Cork best
EddieStone
dazblakey wrote:Is Cork best
No.
