Page 2 of 2
Re: Is this right? Strobing
Posted: Tue Aug 09, 2016 8:09 am
by Snails
vespanic wrote:Have you tried earthing to the frame rather than the battery?
The engine is earthed to the frame - does the battery need earthing too? If so how is this done?
Posted: Tue Aug 09, 2016 8:10 am
by Snails
lambro wrote:Try a different CDI, I have trouble with various ones strobing.
Swap CDI for a Ducati one I have I know works, and almost always get a flash.
Shaun.
OK I mine is a BGM copy but a mate can lend me another of the earth thing is not the issue
Posted: Tue Aug 09, 2016 8:31 am
by EddieStone
I don't think earthing is the issue (bold statement!). I run mine from a separate battery and it works fine. There is no connection between the battery and the scoot other than the sensor clamp on the HT lead. You need power to the strobe, then it's triggered by the high voltage impulse in the HT lead.
I'd check you're getting a spark (which is needed to trigger the strobe) and that the battery is supplying 12V. If you have both of these then the strobe may be faulty.
Posted: Sun Aug 21, 2016 8:58 pm
by Snails
Sent it back and got a replacement and is working now
Posted: Mon Aug 22, 2016 4:16 pm
by Knowledge
I love a happy ending.
