Page 2 of 3
Re: LTH clutch.
Posted: Thu Nov 05, 2015 7:35 pm
by drunkmunkey6969
10 inch Terror wrote:roadrunnerian wrote:will a lth or a/f road be ok for a 30 bhp engine thanks
From what I've read the LTH is good for 25bhp as it comes. The AF Race is slightly higher and should be ok for 30bhp. I'm sure someone will correct me though.
I've fitted the LTH to a few 36bhp RBs and TS1s.....not had any slippage or issues, fit and forget.
Re: LTH clutch.
Posted: Thu Nov 05, 2015 7:48 pm
by jonboy
drunkmunkey6969 wrote:10 inch Terror wrote:roadrunnerian wrote:will a lth or a/f road be ok for a 30 bhp engine thanks
Can I ask which gearbox oil you are using
LTH clutch.
Posted: Thu Nov 05, 2015 9:30 pm
by drunkmunkey6969
jonboy wrote:Can I ask which gearbox oil you are using
Maxima
Re: LTH clutch.
Posted: Thu Nov 05, 2015 10:11 pm
by 10 inch Terror
drunkmunkey6969 wrote:jonboy wrote:Can I ask which gearbox oil you are using
Maxima
l
Ditto.
Re: LTH clutch.
Posted: Fri Nov 06, 2015 12:16 am
by eden
ive rode a 44 bhp Lambretta with one that slipped its tits off in every gear all the time if you gave it a fist full.
Re: LTH clutch.
Posted: Fri Nov 06, 2015 12:36 pm
by Muppet
^^^ ya hooligan ^^^
Re: LTH clutch.
Posted: Fri Nov 06, 2015 1:52 pm
by 10 inch Terror
I'm finding it a bit stiff to be honest. MB cable routed correctly and a yam lever fitted. Did anyone find the LTH a bit stiff at 1st and it loosened off after a few miles?
Re: LTH clutch.
Posted: Fri Nov 06, 2015 2:20 pm
by DigDug
As the man said....
Re: LTH clutch.
Posted: Fri Nov 06, 2015 7:14 pm
by eden
10 inch Terror wrote:I'm finding it a bit stiff to be honest. MB cable routed correctly and a yam lever fitted. Did anyone find the LTH a bit stiff at 1st and it loosened off after a few miles?
the one I fitted wasn't stiff and didn't change over the 1000+ miles I did on it.
Re: LTH clutch.
Posted: Fri Nov 06, 2015 9:44 pm
by gerryjunior
my clutch was stiff at first, its gotten softer after 1500 miles,
