Page 2 of 2
Re: engine won't rev and smokes
Posted: Fri Jul 24, 2015 7:10 pm
by coaster
HxPaul wrote:You say it smokes a lot,is it white smoke,if so it could be your main drive seal thats failed causing your spark plug to become fouled.
Easy test for that is to block the exhaust, if it kills the engine, the seals are ok
Posted: Sun Jul 26, 2015 1:37 am
by nelson pk
Very true, however this test will only work if your exhaust is sealed properly ;)
If you have an aftermarket exhaust and not used sealant on flange joints it will keep running anyway but thick white smoke is def a sure sign of burning gearbox oil.
Check choke is shutting off properly at carb.....change plug and check float and needle operation.
Thats my tuppence worth.
