Battery going flat
purple_pill67
Main scooter: Jet200
Ill give the multimeter a go, how do you mean by wire it in series?
Unplug the + or - from the battery with the multimeter on that plug and the battery?
Ive already fitted and connected up the relay but I guess that I can unplug the wire from the battery
purple_pill67 wrote:Ill give the multimeter a go, how do you mean by wire it in series?
Yes, that is what you do but bare in mind that most meters require you to plug the red positive lead into a different hole on the meter in order to measure amps, sometimes 2 separate amps hols are available in which case start off with the highest amperage and if you get a very low or tiny reading drop down to the lower amperage range. DON'T forget to put the meter lead back in the voltage/resistance position when your are finished or you will blow a fuse next time you use it
