Page 2 of 2
Re: Elecrexworld stators ? ?
Posted: Fri May 01, 2015 7:08 pm
by rosscla
And the suggested wiring for a trickle charge battery with AC lighting is
Posted: Fri May 01, 2015 10:07 pm
by rosscla
I don't see why the two yellows couldn't be plugged into a podtronics / wassell type rectifier and the output used to feed the loom and battery.
Posted: Fri May 01, 2015 10:16 pm
by Yanker
rosscla wrote:I don't see why the two yellows couldn't be plugged into a podtronics / wassell type rectifier and the output used to feed the loom and battery.
That is what I was hoping (Like the look and the provenance of the components provided they have not been moved 'Eastwards' to an un=proven supplier yet again Piaggio!)
Posted: Fri May 01, 2015 11:37 pm
by rosscla
There's no sign of any Markings on any of the parts except the flywheel and backplate.
Couple other pics
Posted: Sat May 02, 2015 12:54 am
by Yanker
At a glance: tkx for the pictures rosscla!
Posted: Sat May 02, 2015 10:58 am
by coaster
I could be wrong but I THINK most bike stators are 3 phase, Wassel do a 3 phase version of their DC regulators but I don't know the wiring configuration.
Posted: Sat May 02, 2015 11:11 am
by carlos fandango
Ive got a 3phase electrex running through a single phase wassel, just connevted the two yellow wires to thr two yellow on the wassel .
My electrex us 5years old and from memory the wires are slightly differen to what's pictered before.
My wireing diagram had the one yellow conected to the reg/rect and the othe yellow earthed ...........same as what you would need to do to a wassel converted stator if you decided to run it through a normal vepsa style reg .
