My cylinder head and other close friends
Grumpy225
At the very least I'd soda blast that cylinder and head to get the corrosion off. It will cool better and make any new problems easier to spot.
Snails
Yes I have been thinking it could do with a clean myself.
By soda blast you mean bicarbonate of soda in a bucket of water? I'm going to clean the exhaust out too in case that is causing the problem.
Snails
corrado wrote:Here's a link to Darrell's kit.
£59. Less than the cost of a new piston.
https://www.facebook.com/27012881976792 ... =3&theater
Thanks. That's tempting. I'm trying to talk my friend into going halves as he would use as much as me. :)
mick1
Main scooter: Li Avanti 225
Snails wrote:Yes I have been thinking it could do with a clean myself.
Soda (bicarbs as you say) is the media used in a blasting machine. The soda is not as harsh as some of the other used (sand, grit, etc).
Snails
Although I think it's caustic soda for the exhaust ?
You can make your own leak down kit using a bicycle inner tube, foot pump any some soapy water. Even if you buy the pump and inner tube it'll only cost £10 or less.
Snails
coaster wrote:You can make your own leak down kit using a bicycle inner tube, foot pump any some soapy water. Even if you buy the pump and inner tube it'll only cost £10 or less.
Yeah I kind of get that, clamp the inner over the carb mouth, and then you block you exhaust with something?
On the kit on facebook, loctite is provided. Whats that used for?
dave411
Main scooter: Li 125
Its a Silicone sealer,put it on the plates?
mick1
Just cut the inner tube in half and connect one end to the inlet manifold and the other to the exhaust stub (or tail pipe). Just done one on my Avanti and used it again on my Rapido......worked at treat, sprayed with soapy water and I had bubbles coming from everywhere :oops:
Identified leaks/fixed and re-tested......tighter than a ducks ar*se :D
Snails
Cool I will give it a try when I reassemble - I have an old lambretta inner which I will try first
