Page 2 of 2
Re: Wide Rear Tyre Conversions... R they any Good?
Posted: Sat Sep 12, 2015 11:26 am
by cartmel808
Mines the same - & as you say, the engine offset would need to be nearer to 15mm to properly centre the tyre with the frame.
Not the most practical of conversions either - in that you basically have to drop the engine out of the frame in order to remove the rear wheel ...but I still think they look the bollox though....
Posted: Sun Sep 13, 2015 9:57 pm
by MCH
On mine all I have to do is remove exhaust and undo rear shock, gave enough clearance to remove 130-70 and 120/90
I was also looking at an lml auto the other day and I'm sure the panels look wider than Vespa, going to have to borrow one and see if they are, if so I could then shift the engine over another 5mm
Posted: Fri Sep 18, 2015 5:04 pm
by nam65
Hi all
i am interested in doing this conversion what stops the wheel from
being removed with engine in the frame also any issue with rubbing on the clutch cover
thanks in advance
Posted: Sat Sep 19, 2015 12:45 am
by cartmel808
nam65 wrote: "what stops the wheel from being removed with engine in the frame"
thanks in advance
The width of the tyre takes up most of the space in the wheel well - so you no longer have the clearence to remove the wheel from the hub with the motor in place.
I used the scooter & service conversion on mine which uses a cnc'd billet spacer between the wide halfs of a px & cosa rim with a 130/70 tyre - and it comes with longer replacement studs for the hub & a spacer for the engine mount included in the kit.
I replaced the existing engine mounts with the Jockey's wide tyre mounts with built in spacer & also fitted a cosa front rim with 100/90 tyre which compensates for the offset of the rear wheel... no issues with tyre rubbing on clutch cover.
Posted: Tue Mar 01, 2016 11:47 pm
by James
Thinking of getting the scooter and service widë tyre combo as looks the nutz.
Is there any mod needed to the rear brake lever, on their site it mentions something about the rear brake but not very clear.
Thanks
Posted: Wed Mar 02, 2016 12:21 am
by cartmel808
James wrote:Thinking of getting the scooter and service widë tyre combo as looks the nutz.
Thanks
No - you just need to change your rear hub studs for the longer ones supplied with the kit, cut 10mm off the rhs pivot mount & fit the supplied spacer to other side.
Posted: Wed Mar 02, 2016 12:59 am
by James
Sounds easy enough, are you running a 130/70 - 10 tyre, and hows about the front, standard 3.50 or wider?
Posted: Wed Mar 02, 2016 8:24 am
by cartmel808
130/70-10 on the rear - and on the front i'm using a cosa rim with 100/80-10...
Also - check if your exhaust will fit with wide tyre... a lot of the off the shelf left hand side expansion systems wont.
Posted: Thu Mar 03, 2016 12:40 am
by James
ok thanks for the info, I'm going to change my old Taffspeed and looking at a German Pipe Design exhaust so no worries there, looks like a little visit to SIP website for so money spending!
