Re: So,what caused this then??
Posted: Sun Nov 02, 2014 9:53 am
Was the piston seized in the bore?Spigot casting probably smashed by flailing con rod.
Piston not seized,but probably as suggested,piston skirt cracked,lodged in a port then BOOM!!!!dave411 wrote:Was the piston seized in the bore?Spigot casting probably smashed by flailing con rod.
they always seem to run at there best just before they go BANG.kevspeed wrote:Top ring is present,small end is still free,mains are good,mostly suprised at the chunk of barrel spigot thats smashed off,and the fact that the engine casing isnt damaged!Yanker wrote:SIL rod failure due to excessive piston to bore clearance (evidence the blow-by), Ring failure (where is the top one). Small-end bg failure: check as suggested by roscalla. Pics are poor: check big-end and main bearings. Coupled with poor quality components?
Original 1979 Indian 150cc motor,no modifications except for a 12v electronic,as the lights on the original points set up were dire!,pity as was running faultlessly,still,its Lambretta isnt it!
