Page 2 of 6
Re: Spluttered. Won't rev
Posted: Sun Jul 06, 2014 7:25 pm
by mick1
fuel cap breather hole ? try without cap on (not with a full tank!!)
Posted: Sun Jul 06, 2014 8:12 pm
by biddy
check pilot jet hasn't come lose ,had the same problem done everything but check carb
Posted: Mon Jul 07, 2014 10:29 am
by vRSG60
Same thing happened to mine.
Started 1st kick but wouldn't run or rev more than 2 seconds. Changed plug same again, changed plug same again etc.........
Changed CDI unit everything worked fine.
Posted: Mon Jul 07, 2014 1:02 pm
by Bilko
Flywheel hasn't moved from the woodruff key.
Ignition is ok (took green from loom out of the CDI).
I'm hoping it's carb related. Just stripping it now to clean. Hasn't been cleaned in a long long time. So here's hoping. :/
Posted: Mon Jul 07, 2014 4:14 pm
by Bilko
Changed everythng. Carb, CDI, plugs etc. Wants to start but if it does it's only for a couple of seconds.
Posted: Mon Jul 07, 2014 4:23 pm
by vRSG60
Well it can only be 1 of 3 things -
Air
Fuel
Electrical
Posted: Mon Jul 07, 2014 4:54 pm
by Bilko
Stator readings from multimeter are within the range according to Sticky's manual.
Posted: Mon Jul 07, 2014 5:55 pm
by goldeneye
fuel tap is fooked,thats my guess.
Posted: Mon Jul 07, 2014 7:32 pm
by Bilko
Fuel tap working correctly - Just checked flow.
Posted: Mon Jul 07, 2014 8:03 pm
by johnd
Sticking float.
