Removing Paint
GLscoot
Main scooter: Vespa GS150
Do they not have horses with larger tongues
mark1
Main scooter: gp
Submerge the parts in a strong solvent (Zylene based would be your best bet). You should be able to get it from a local paint supplier, Industrial paint supplier would probably be better than an Automotive supplier.
Oh yeah, don't use a plastic bucket to hold the solvent in like someone I know :lol:
mick1
Main scooter: Li Avanti 225
ducksta
is that gravity fed mick carnt see a trigger
GLscoot
ebay item number 111216372370
would this be good enough for the sand blasting and a little paint work. Checked machine mart they start at £500, fck that.
Cellulose thinners or Acetone will do it. But there is a lot of elbow grease involved and you need to be in a well ventilated space.
diesel
ducksta wrote:is that gravity fed mick carnt see a trigger
The trigger is the button on the shaft, you hold it penwise and push the button with your index finger
Looks a bit like a modelling air brush. Similar principle I should think.
