Removing Paint
Submerge the parts in a strong solvent (Zylene based would be your best bet). You should be able to get it from a local paint supplier, Industrial paint supplier would probably be better than an Automotive supplier.
Oh yeah, don't use a plastic bucket to hold the solvent in like someone I know
is that gravity fed mick carnt see a trigger
- Doom Patrol
- registered user
- Main scooter: Jet 200
- Location: Second star on the right and straight on till morning
- Contact:
Cellulose thinners or Acetone will do it. But there is a lot of elbow grease involved and you need to be in a well ventilated space.
- diesel
- registered user
- Playstation gamer tag: speilekorps
- Main scooter: lambretta li 150 s1 1958
- Contact:
The trigger is the button on the shaft, you hold it penwise and push the button with your index fingerducksta wrote:is that gravity fed mick carnt see a trigger
- Doom Patrol
- registered user
- Contact:
Looks a bit like a modelling air brush. Similar principle I should think.
