Page 2 of 2
Re: Vespa casings - Lambretta barrel
Posted: Sat Nov 02, 2013 7:12 pm
by grimspeed
OzOAP wrote:I did some work on some casings about 5 years ago.
LML reed casings, P2 crank, Malossi 172 T5 barrel. Would make a 190cc.
Packer bolted to casing and barrel studs into packer.
I like that ! Could you use a runner cylinder the same way ? what rods on that ?
Posted: Sun Nov 03, 2013 12:02 pm
by OzOAP
Used a 115mm rod. Packer was 13mm.
Maybe if you go 60 stroke and use 16mm packer, then you could use packer as a water inlet into bottom of barrel.
Now I've got a workshop again, would love to get a mill and lathe again so I can 'tinker'
Posted: Sun Nov 03, 2013 12:08 pm
by grimspeed
Cheers Oz ! I smell a cheep 190 Lc coming !
I think 60 may be to far for the transfers and I want to keep it simple !
Going to buy a NGF 172 kit on Friday and give it a go !
Thinking of blocking the water inlet and fitting a tube to the side of the cylinder
for a inlet ?
Posted: Fri Apr 17, 2015 9:05 pm
by ipman
oz how much for a px/t5 conversion?
Posted: Thu Apr 30, 2015 4:22 pm
by oldbiker
why limit yourself to just using a lambretta barrel. if your considering all that work there must be better topends to fit say something off a 200-250 jap bike
Posted: Fri May 01, 2015 4:19 pm
by shocky
oldbiker wrote:why limit yourself to just using a lambretta barrel. if your considering all that work there must be better topends to fit say something off a 200-250 jap bike
Sounds good but most are high revving with narrow powerbands and more suited to 6 speed gearboxes than 4 speed
Posted: Mon May 04, 2015 9:00 am
by OzOAP
Could fit a Kwakyamazuki top end but a lot of people would just walk passed with no interest.
Fitting a TS to the P Range kept it 'scooter', and gave birth to great comments from certain members of our society, like, "what a waste of a lambretta barrel"
Posted: Tue May 05, 2015 3:58 pm
by shocky
I know of a rather nice T5 with a honda RS cylinder fitted im sure its now a 152 and the owner who I know through VCB said it was 32bhp I think there more of a challenge to fit a bike barrel than one of another brand of scooter
