BGM Stator/Flywheel Poll
What Flywheel combination with BGM Stator
BGM + Indian Sil Flywheel
12
48%
BGM + AFR Light Flywheel
5
20%
BGM + AF Ducati Flywheel
5
20%
BGM + Other Please specify
3
12%
Total votes: 25
goldeneye
slightly off topic, but a mate had an indian stator and AFR light flywheel fitted, and his rev counter wouldnt work properly, swapped to a BGM stator, and BINGO! rev counter working properly!
J1MS
Jonny G wrote:Af Lightened Flywheel, BGM 120W Stator and an MEC Crank. 1mm machined from the mag housing face. 300 miles with no probs whatsoever !!
Wouldnt try to run one without first removing 1mm from mag housing.....This is a combination I have fitted with no problems also fitted to an MEC crank.... 8-)
ArKaTxU
RinB wrote:Any more voters
Another question are the AFR light flywheels old or new type ie new have a packer in between
boss & flywheel.
Also 120w BGM old or new ie new ie pickup is no located futher in Ie laminates taken off
from manufacture.
How to know if a flywheel is a new type? and the same with the BGM stators.
