Malossi 210 pinging in mid range
bogs
Norrie Bodge wrote:
bogs wrote:Set up is malossi ported barrel and matched case transfers , 16' ignition , 1.25 mm squish, jl pipe and standard carb.
It pings its head off at about 6000 rpm, so mid throttle in 4 th.
I've tried with 140 air corrector and be4 in carb as been advised but tbh the 140 makes it 4 stroke.
Any ideas of how to stop pinging would be appreciated
read here may help -> http://scooterotica.org/forum/viewtopic ... 40#p199440
& listen to the video in post #1 helps you understand how the emulsifier/atomiser works
Thanks that post norrie bodge, its very good info. I have a full range of emulsion tubes so will have a play and maybe add or take away some of the holes
