dellorto fuel pump
gimp1971
Main scooter: vespa t5
Diablo did mine on my T5 if you want will take a couple of pics of it and mail them to you
barneypeter
gimp that would be great this is a diablo built engine ,is vacume on casing or carb,and is there any restrictors in fuel line many thanks,and thanks for all other replies pics very helpfull
gimp1971
will sort some out for you tomorrow if you want to pm me your email
dopeshots
Xbox live gamer tag: rms789
Main scooter: GP150
Why does the vac fuel pump get used and not an electric one?
Russ :fb:
gaz_powell
vacuum pump is a simple "mechanical" answer it works with the suction of the rotating crank - so as long as the crank is turning the pump is working - you cant get caught out if you have some sort of electrical failure leaving you short of fuel.
dopeshots
Main scooter: GP150
so its nothing to do with fuel pressure or any thing like that then. Ok brilliant I'll look into getting one fitted to mine.
Russ ;o)
