dellorto fuel pump
gimp that would be great this is a diablo built engine ,is vacume on casing or carb,and is there any restrictors in fuel line many thanks,and thanks for all other replies pics very helpfull
vacuum pump is a simple "mechanical" answer it works with the suction of the rotating crank - so as long as the crank is turning the pump is working - you cant get caught out if you have some sort of electrical failure leaving you short of fuel.
