Page 2 of 3
Re: Wosner piston
Posted: Mon May 27, 2013 8:36 pm
by Yanker
sydduckett wrote:the rings pegs were moved slightly on different years. Id have to look back at prev posts re this. I wanted to try and get it from AF but if they havent got anything to suit ill have to have a think about where to go from there....bugger...
yep, got caught-out in that one miself: top peg runs
very close to the boost port edges.
http://www.lambretta-teile.de/Kolben-66 ... tta-RB20_1
Re: Wosner piston
Posted: Mon May 27, 2013 8:40 pm
by Darrell Taylor
you could post the cylinder to af and get them to check the clearance or ask if they dont mind you buying the largest for you to check then refunding if its too big on clearance
Re: Wosner piston
Posted: Mon May 27, 2013 8:47 pm
by Spanish Fly
Ceramic coat the piston?
SF
Re: Wosner piston
Posted: Mon May 27, 2013 9:01 pm
by sydduckett
I hope so, will be a right balls ache if i have to hunt down a piston nearer my bore.
Re: Wosner piston
Posted: Mon May 27, 2013 9:03 pm
by sydduckett
Spanish Fly wrote:Ceramic coat the piston?
SF
can that be done? Wiseco are a good piston. Dont know if they will go with an rb?
Re: Wosner piston
Posted: Mon May 27, 2013 9:09 pm
by sydduckett
Yanker wrote:sydduckett wrote:the rings pegs were moved slightly on different years. Id have to look back at prev posts re this. I wanted to try and get it from AF but if they havent got anything to suit ill have to have a think about where to go from there....bugger...
Do you know if this is 66 dead? Thats a lot closer to my bore. Could be the go. Please dont tell me these ones have the potential peg position....
Re: Wosner piston
Posted: Mon May 27, 2013 9:14 pm
by sydduckett
thesx200 wrote:Why not re-peg the piston
To be honest id rather keep it as a spare as its a cheapo and put the best in i can afford. The 5 speeds been in its box since Wicksteed and the iv finished paving the drive so im back on the rebuild. Hoping for a wet one tomorrow so i can get a day in the garage......Is that wrong.....
Re: Wosner piston
Posted: Tue May 28, 2013 7:16 am
by Eibar
"ahem "
We run a wiseco piston in our RB20 , worth ringing ben and seeing if he's got any to suit.
Re: Wosner piston
Posted: Tue May 28, 2013 10:31 am
by Muppet
too many chiefs not enough indians
Re: Wosner piston
Posted: Tue May 28, 2013 5:13 pm
by sydduckett
Eibar wrote:"ahem "
All well and good but is it the right side of 66....
