WORB-5 head
LI150
Main scooter: Series 2 LI150
ssteam177 wrote:With the malossi head I personally found the compression ratio too high at 12:1 so I switched to the mmw but if I was building one now I'd use the sip head
I have had all 3 head
My take on it is the malossi the compression seemed to high couldnt stop it pinking
The MMW compression was lower didnt pink but lost power
The sip head I would say the best part I ever bought for a Vespa
Dryballs
Yep what li150 said
My setup is malossi 210 with self reedvalved casing and keihen 30mm carb and sito exhaust
It's a really rapid and torquey motor
ssteam177
Main scooter: vba malossi 221, api series2
Interesting: Is your's standard stroke? (12:1 is too high for me too!)
No it's 60mm stroke with the packing plate at the base of the cylinder( rd350 reed mmw2 reed block 30mm pwk carb 1650g flywheel 23hp)
IT'S NOT WHAT YOU BUY
IT'S WHAT YOU BUILD!!!!
