Page 2 of 3
Re: Winter/rallymaster mudguard brackets
Posted: Sun Dec 30, 2012 12:23 pm
by soulsurfer
Hi Gaz, I didn't do this conversion, I got Spanish forks, I could measure the collar and come back to you, remind me in a couple of days if I forget ;)
Posted: Sun Dec 30, 2012 6:33 pm
by gaz_powell
Cheers Soulsurfer that would be gratefully received
frame and forks will be going to the welders w/c 07/01/13
gaz
Posted: Sun Dec 30, 2012 9:10 pm
by Andy Pickering
soulsurfer wrote:Hi Gaz, I didn't do this conversion, I got Spanish forks, I could measure the collar and come back to you, remind me in a couple of days if I forget ;)
Put the bloody lego down and check it for him Mike :grin:
Posted: Sun Dec 30, 2012 10:13 pm
by soulsurfer
:lol:
Posted: Mon Dec 31, 2012 10:44 am
by soulsurfer
Okay, mine are powder coated so allow for this, although there's plenty of room for tolerances, the height is 16.5mm and the outside diameter is 68.7mm, so aim for 16mm and around 68mm and you'll be fine.
Posted: Mon Dec 31, 2012 6:05 pm
by sydduckett
Thanks for the pics and measurements Mike. Im right in thinking they are the correct Spanish ones in the pics that we need to copy? Sorry just being a bit thick...again. Im waiting on a password to be re-sent from photobucket and then i can hopfully get some pics up for advice before i start cutting bits off my forks..... :? :D
Posted: Mon Dec 31, 2012 7:01 pm
by sydduckett
Okay, hope these come out. Below are some pics of the Indian Li with turning mudguard now off. Also the pic of the turning mudguard im using with the locking ring attached. Am I correct in saying that the dust cover needs to be discarded then a ring (as per soul surfers measurements) welded in its place?
ta
Sef
And heres on of the scoot itself, will be running as is for a while. In process of seeing if points are up to it before I weigh out on a 12v. Im trying to do this as cheap as poss as i seemed to spent a small fortune on the RB. At some point in the future Id like to put an rb250 in.....but thats for another day.... :D
sef
Posted: Mon Dec 31, 2012 8:41 pm
by soulsurfer
It looks like you just need to weld the collar on your forks and you're good to go ;-)
Posted: Mon Dec 31, 2012 10:27 pm
by sydduckett
soulsurfer wrote:It looks like you just need to weld the collar on your forks and you're good to go ;-)
do you mean under the dust cover? Would I not need to remove this first or can i leave it as is?
ta
Posted: Tue Jan 01, 2013 8:43 am
by soulsurfer
You don't have a dust cover on your forks, it's on the frame, this will need removing for the forks to fit.
