throttle return
Minority
Main scooter: Li230 S3
Andy Pickering wrote:
Whats the spring from ?
http://www.scooterrestorations.com/lamb ... h-serveta/
Throttle Shaft Return Spring (Spanish Serveta)
Not quite. In my case it was off a Multi 1250 printing press :biggrin:
(and I thought I was being very clever and original :roll: )
Angry Bloke
Ta very much :D
DigDug
storkfoot wrote:Late model Lynx models had a spring mechanism deliberately designed to spring the throttle closed. But, Lynxes had indicators. If you read Lammy manuals from the mid sixties, ie before indicators, you'll see they refer to the need for the throttle to bind deliberately. As Chris, says this is so the throttle doesn't completely close whilst you're indicating to turn right.
So did early Lince models (1983).
Did you have to do that?
kev.ts1
Main scooter: SX200
It's all return in here somewhere--- http://www.motuk.co.uk/manual/mc_contents.htm
