Page 2 of 3
Re: panel hole and airscoop
Posted: Fri Mar 16, 2012 1:34 am
by rosscla
But if you want that 70's / 80's 'bodge it ' look then what could be better than bolting an S2 air scoop to the panel of your GP? :D
Posted: Fri Mar 16, 2012 7:57 am
by stew
:lol:
rosscla wrote:But if you want that 70's / 80's 'bodge it ' look then what could be better than bolting an S2 air scoop to the panel of your GP? :D
Posted: Fri Mar 16, 2012 10:29 am
by paulmgreen
:D :D
Cooler air is always good to get into the carb area!...... I wouldn't worry too much about rain.............
by mcbrid
Works fine on the Black Pearl (Scootering Mag - Sept '11 ish) with an RB 22/fat Mamba.
You need to grind back the top edge of the scoop to help it fit flat on the panel and I used a GP scoop with nothing inside
I fashioned some fine mesh to fit inside just to stop your flares/oxford bags getting sucked in
No idea if it makes any difference to performance just like the 70's look.
:D
Posted: Fri Mar 16, 2012 7:01 pm
by DaveTomo
You say it like its a bad thing :lol:
Next stop Q max cutter
:D
Me too,I'm going to go for a Chas Fabs panel grill ,then maybe do the airscoop thing,got a GP scoop in the shed,I did wonder about having to grind it down a bit to get it to fit on a SX panel,thank you for the tip.As Paul said cooler air has got to be a good thing.If our Mrs goes on the back she'll just have to wear water/petrol proof over trousers :shock:
And a genuine thank you to Muttley for contacting me with another take on the idea.Thank you mate.
Posted: Thu Mar 22, 2012 11:46 pm
by molibdimum
Better late than never.
Posted: Fri Mar 23, 2012 8:49 am
by DaveTomo
now that ^^ looks the dogs dangley bits,and thank you for taking the time to put the picture on
Posted: Fri Mar 23, 2012 2:22 pm
by SKP
Off work today, so got scoot out for a quick fettle and thought I'd show my side panel Image
Posted: Fri Mar 23, 2012 4:20 pm
by molibdimum
Get yer panels out for the lads :D
Posted: Fri Mar 23, 2012 9:37 pm
by storkfoot
This is on my GP. On the other side it has a metal flap to direct air into the flywheel. Done many, many years ago by a previous owner of the panel:
