Page 2 of 2
Re: Settings Jetex 22mm+Stage4+Sterling exhaust
Posted: Tue Feb 28, 2012 10:47 pm
by mark
what slide you using
150
200
Posted: Tue Feb 28, 2012 10:58 pm
by WINTERMODEL150
mark wrote:what slide you using
150
200
Check you out with fancy pics :frog:
Dean
Posted: Tue Feb 28, 2012 11:01 pm
by mark
nicked from scooterrestorations but you mustnt tell
Posted: Wed Feb 29, 2012 10:57 am
by KOREBCN
Mi Jetex is 200 is simple!
goood.
Posted: Wed Feb 29, 2012 11:20 am
by KOREBCN
Posted: Wed Feb 29, 2012 1:17 pm
by Toddy
WINTERMODEL150 wrote:
gerryjunior wrote:
WINTERMODEL150 wrote:Hi,I take it you have a 200 jetex carb and not a 150 as the slides are different,you should be running a 48 pilot jet if not change it.
The engine not up revolutions :wtf: will it tick over smoothly?sounds like you my have others issues.
How do you tell the difference between a 200 and a 150 jetex.. i know the dellorto had different slide no's but i dont remember seeing no's on a jetex?
The 150 slide on a jetex has a cut out in one side of the slide the 200 doesn't simple :D
Dean
And the atomisers are different
