clutch help
tony
Main scooter: 90ss
clutches get hot of course.. expand and if you dont have enough slack in the cable this can cause them to slip. usually tho it will continue slipping if this is the case. I'd think it more likely the outer is too short or it caught on something.
when i strip at weekend i will investigate
mark wrote: "dominic cant be arsed "
thats not good is it :evil:
goldeneye
you still after some vespa springs for your motor? pm me your address, i"ll send you some for nowt. ;)
Bilko wrote:Just measured them at 2.50 with digi callipers
yep, found them, a smidge over that with old school micrometer...
that jeff's a good bloke, eh ?
Latest update: went out on bike today and it wasn't ticking over evenly so took for a little ride and got to traffic lights and tick over was up to about 4k. Turned round to go home, got about 100 yds and revs went to 8-9k shut ignition of and it kept screaming so I stalled it. Stripped panel of and found a huge crack in my inlet manifold so I'm hoping it isn't a clutch problem but will know more next weekend.
Bilko
Main scooter: LI150
Good find Mark. If you know what I mean, could have been a disaster.
Bilko's Oily Blog
Hopefully this is my problem 8-)
latest update . i have found what cracked my manifold ,it was my rear set bracket bolt fouling it and manifold moving against it stressed it. sorting tomorrow
mark wrote:latest update . i have found what cracked my manifold ,it was my rear set bracket bolt fouling it and manifold moving against it stressed it. sorting tomorrow
cool. always good to find the cause of a problem
