Re: BGM Rear Light Reflector
Posted: Fri Aug 13, 2010 8:44 pm
yes mine's very bright and looks the bizz
got mine from broady's
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
I cut the lugs off with a dremmel and then used some perspex sheet cut to the shape of the light housing and glued that in place, then drilled a hole in it for the wires and fitted a grommet to keep the elements from getting to the LED board, then drilled a hole at each corner of the LED and screwed it into casing using small washers to space the LED board away from the perspex, job dome. Much less hassle if you've got the flat housing like Lam46 though.coaster wrote:It's really simple to convert a GP rear light housing to take the LED but it is a non-reversable process. You just need to carefully cut the raised part of the reflector off (I used a wood saw) so that it is level with the outside of the housing and then use plastic metal to glue the LED board into the housing taking care not to bridge the copper strips on the rear of the board with ther filler (just in case it is conductive enough to cause problems.
Whole job took 30 minutes
Bilko wrote:Thanks for the help lads. Got mine today via Corrado and it wasn't hard to bodge with the dremmel & some silicone.
