17lt Stainless Tank and 24mm Delly.....
- corrado
- Dealer
- Main scooter: Lambretta GP
- Contact:
Ah, sorry Pete I forgot about the pictures. I'll try and dig them out on Monday. I have got some rubbers for TMX35 that are more than double the normal length, so using one of those cut down would probably help with the depth problem, just a case if they'll then clear the panel. Had the 34 Delly and TMX side by side yesterday (but no camera) and the TMX is tiny compared to the delly. I've also got a 34 mm KOSO and that's even smaller though not quite as thin for panel clearance as the TMX.
Hi,
Noggin1969
you posted that a tmx35 would fit under the tank i have, do I need to use a different manifold and/or offset cones as well?. I have the hagon short rear shocker fitted at the moment
Pete
Noggin1969
Pete
Hi Pete.
I have a TS1 240 with a TMX35 this gives fantastic fuel economy for what it is and i have a Diablo Tank its real easy to fit and there are no clearance issues at all mate.
Regards Dean
Regards Dean
I RAN OUT OF SICK DAYS SO I DECIDED TO RING IN DEAD
- noggin1969
- registered user
- Contact:
I'm using offset cones and a standard TS1 manifold ( i have a MBR 1 with pack plate and yam reeds but not got round to fitting it yet
) and a R1 shock and it fitted fine. I now use a Diablo tank but both the 34 Amal and 35 Mikuni fitted with the stainless tank
- Attachments
- DSC00089.JPG (187.87 KiB) Viewed 1597 times
- RED GP 001.jpg (155.96 KiB) Viewed 1597 times
Has a mind full of useless s**t and isn't afraid to use it !
