Gudgeon Pin Shims
Jeff T
Main scooter: GP150 & LI150 S2
Should I shim the gudgeon pin when fitting an Imola, read arguments for and against.
wack 63
Main scooter: '71 GP TS1
Depends on the crank used whether it has shims or not although Mr. Webster once told me not to use any whatever crank I used.The main problem is finding some good enough to use especially in a high revving kit like the Imola,but that's my opinion.
Speed Demon
Don't think you should fit an Imola to any crank that doesn't have big-end shims - in which case gudgeon pin shims aren't required.
You can get decent race-type cranks for little more than £100 from the likes of JB tuning or PM - its a false economy to use anything lower spec than that.
Get to SULK
    Users browsing this forum: Google [Bot], Semrush [Bot] and 1 guest
