Rubber O Rings for Bullets TS1 exhaust?
wax
I had a new exhaust from SIP, that looks great but it did not come with a couple of rubber o rings for the manifold. After half a dozen emails to SIP (they keep telling me i need a beedin' gasket kit!) I took it to an MX mate of mine who said his KTM had a similar set-up and so i ordered a pair of rubber rings to fit a 250 KTM, but they are too dam big. £12 quid lighter and a scooter still in bits.......
Do i need Viton seal for an exhaust or summat else? I wanted to get a dyno run and get on the road, but this hole thing is turning into a right pain in the arse!
http://s634.photobucket.com/albums/uu68 ... ullet2.jpg
http://s634.photobucket.com/albums/uu68 ... ullet1.jpg
P.S. i hope these links work. I am rubbish with computers (as well as scooters)
leigh
That loks very similar to the style that is on my franspeed sure he does replacements on his website
Leigh
wax
is this what you mean? It does not say if they are rubber or not. Its a rubbish picture too......?
http://www.ekmpowershop12.com/ekmps/sho ... -336-p.asp
Adspeed
Just completed an exhaust shoot out today-15 pipes I think!! One was the Bullet, no O'rings also............We used HT Sealant as needs must........
stefan 231
Main scooter: Lambretta, PX
Hi.
The material of the missing rings are viton.
diameters 40 x 1,5 mm.
best regards, stefan
leigh
wax wrote:is this what you mean? It does not say if they are rubber or not. Its a rubbish picture too......?
Couldnt say from that picture to be honest, sure if you ring he could answer or do as others have said used a sealent.
Leigh
ArKaTxU
I use sealant on my JL Franspeed and goes well.
wax
What like a special high temp paste? Any brand in particular chaps?
leigh
Adspeed wrote:Just completed an exhaust shoot out today-15 pipes I think!! One was the Bullet, no O'rings also............We used HT Sealant as needs must........
are you going to put the results up here
Leigh
wax
Do you mean dyno results? If so then yes no problemo. I am aining for 30th Jan at Diablo, but i havent booked yet. I need to get my EGT weld on boss fitted too. I have emailed MD developments, but they have not replied?
I have also ordered some viton o rings from AF rayspeed. So hopefully they will fit. My ts1 240 made 36 bhp on JB tunings dyno with a franspeed. It had a little more porting on the cases, when i had it stripped last by JB, so with the Bullet i am hoping for a few HP more.
