Rear lights
sydduckett
Iv cut vents into the rear of my panels and want to put some additional rear lights in them behind the wire grills im puting in. Ideally looking for lights that work on both rear light and brake. They will need to be quite small and have a connector on the back so i can disconnect them when taking the panels off. Im thinking LED or similar? I am running 12v without a battery.
sef
rbgaz
av look in halfords sef they do allsorts 12v led stuff
sydduckett
rbgaz wrote:av look in halfords sef they do allsorts 12v led stuff
need some easy to disconnect connectors as well
essexgp
I think this would work for what you are wanting to do
http://www.maplin.co.uk/Module.aspx?Mod ... connectors
:idea: :)
ratty
Main scooter: LI ser3 125 {TS1 230} 1963
hi, you could modify the led stop and brake light unit thats already available for lammys, if your handy with a soldering iron and a bit of fettling,buy the whole unit and you will have everything you need.
how much!!!
Knowledge
Sef,
You can pop over to mine (A12, south of Ipswich) and see some conenctors I have in stock, along with cables, terminals, tools and my own versions of LED lights that I have fitted to the Abarth.
Martin
sydduckett
Knowledge wrote:Sef,
Mart, how about i pop over to yours with a some cash pick what i want and then have a cup of tea while you fit it for me... ;) Im not to clever with the old electrics and someone like you could do this whilst asleep. I will be happy to pay for the labour. Shall we say £15ph. im guessing 45 mins and a couple of gary baldies and all will be done...
You know it makes sense.... :D
Knowledge
OK, I'm (probably) up for that, but I don't have any lights to fit, only examples of what you could buy to suit your own requirements.
You don't want a battery, but LED's will not work at their best on AC power alone.
Martin
