What do you make of this...?
Timbo
...............and will it live.... :roll: ................. :lol:
CANbus
I'm sorry I can't help, with a bit more info you may get a response however, set up, symptoms etc
11111111 = 0xFF
Looks like a standard 150 to me. Could be wrong though.
What is it we're supposed to be seeing?
AUSSIE
It looks ok port wise, just blow by past the piston rings.
New rings or a rebore.
Timbo
AUSSIE wrote:It looks ok port wise, just blow by past the piston rings.
Thanks Aussie, i got the response i was after from the "Feckers" .....and your spot on although a grown up showed me there was a crack on the piston :shock: . New piston and a rebore is in hand.... ;)
dirtyhandslopez
A grown up with good glasses :) I could barely see that in the picture.
That's not going anywhere...
