Horn
dapper
Having just completed my Injun Vijai Super resto, have the ubiquitous duck fart AC horn. What can be done to make it at least audible :roll: Is there another type of horn that will sit on the same bracket under the horncast that could be heard by pedestrians/car drivers?
wack 63
Main scooter: '71 GP TS1
Have you 12 volt electrics? If so I have found 6 v horns give more volume although it's still a duck fart but thru nipped cheeks.....
Honeymonster
Hi Mark, tried a few different horns but all gave typical duck fart noise when needed, have come to the conclusion that a full DC conversion, with a battery wired in, is the only way, you usually only need a horn when your throttles closed and braking. I got a horn from a company called Acumen which is very good but have tried a very cheap DC unit and it was fairly good.
Otherwise it's a gas canister and air horns, very 70's
good luck Ian
If you fit a battery, I can recommend a Stebel air horn. Wouldn't fit under the horncasting, but they're reasonably tiny. You could hide it underneath quite easily.
dapper
Yeah, my other Bitsa has a DC horn fed via a battery in the toolbox and its feckin loud. May have to go for that
i think the duck fart horns are quite funny :D
    Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 3 guests
