Ring Life - standard engine
sideout
What sort of mileage would you expect to get out of a set of piston rings in a standard SX150?
Thanks in anticipation :wtf:
bristolmod
standard as in an air filter fitted and running, say semi synth at 3%.
I recon anything between 5 and 10,000 miles at a push
Chris
Scootering since 1968.
sideout
Cheers Chris
Air filter, 22mm Jetex, Clubman and 4% Rock Oil Semi-Synthetic.
bristolmod
yep- I'll still go with 5k minimum. If it then needed new rings, I'd probably go for a rebore and new piston rather than faff around with just rings
Chris
joey
...keep going until you loose compression...decoke at around 5000m and check ring gaps.....modern oils should keep the carbon clear for longer though...nice loose barrels let the engine rev freely....
if in doubt bin it and fit a mugello.... :lol:
soosh
You should be fine for at least 10k. Ive probably done that on a standard piston with open mouth carb on a revier motor so no worries.
Special X
20k plus no worries. Even a tuned mugello (rock hard nicasil bore) will do 10/12k set up correctly with 3% synth and an air filter.
