WHAT TYPE OF CLUBMAN IS THIS???????
shamrockexpress
All I know about this exhaust is that its 40/42mm, loud and really revs out compared to my AF CLUBMAN.
So i,m wondering is this an ancollotti, RS or Chiselspeed modified ( i know for a fact a mate bought there in 1996 I was told at that time Sir Ralph was making them for martin cook)
I HAVE MARKED THE WELD MARKS (if thats any help)
bottom is standard, middle is AF and top is ????????????
basically its a std type box silencer,modified somewhat but will still just strangle any sort of peformance....and nasty looking to boot :lol:
shamrockexpress
sean brady scooters wrote:basically its a std type box silencer,modified somewhat but will still just strangle any sort of peformance....and nasty looking to boot :lol:
Thanx for the info, but this exhaust revs on much further than the AF clubman and has been factory fabricated by the looks of it :? :? :?
I appreciate it looks s**t and its also lighter than the rest so maybe not good quality!!!!
I ve never came across or seen a RS clubman before so JUST HOPING !!!
goldeneye
looks like an indian big bore to me. standard fitting on late indian GP200"s.
eibargum
I havent seen Indian big bores with that extra tail pipe support before, but that doesnt mean its not one, but i have seen Ralphs pipes with them on, he also used to reduce the seams on pipes, like the one in your pic, i dont suppose you know if you have the correct U bend, if you do and its a RS pipe it will be a perfect fit and not rearly require a clamp :D .
shamrockexpress
eibargum wrote:I havent seen Indian big bores with that extra tail pipe support before, but that doesnt mean its not one, but i have seen Ralphs pipes with them on, he also used to reduce the seams on pipes, like the one in your pic, i dont suppose you know if you have the correct U bend, if you do and its a RS pipe it will be a perfect fit and not rearly require a clamp :D .
YES MATE IT HAS A PERFECT SLIP JOINT FIT WITH THE DOWNPIPE :? :?
IF ANYONE OUT THERE HAS A RS CLUBMAN THEY WILL KNOW FOR SURE (they cant be that rare) :wtf:
Stokie
I understand that the U Bend that is used with the RS Clubmans is made from 2 pieces ....
camel
it certainly looks the same as the rs clubman i had on an old bike,it did hace a distinctive "crack" to the tone and performed more like an expansion,if i remember correctly the u bend was 44mm id which is an odd size for production clubmans...perhaps that could identify it?
eibargum
Stokie wrote:I understand that the U Bend that is used with the RS Clubmans is made from 2 pieces ....
The one Ralph made for me had a one piece U bend, as did both of my mates, but he may have made some two piece ones, who knows what he,s made apart from Ralph, they are not all the same either, he used to shorten the swan neck on some pipes to get the box up tight under the footboard, depending on what pipe he started of with, if it doesnt fit like a glove it aint one of Ralphs :lol: .
YAMLAM
Looks like my RS Clubman that i bought in about 2000, mine has RS engraved / scribed on the bracket that bolts under the casing
win or lose have a booze
    Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 4 guests
