Mugello Damage
des
Would i need to replate this barrell, i can fit my finger nail in it, its a mill deep could i just replace the piston and run it as is. The small end bearing failed and did the damage
Markus
That needs replating or replacing. The plating will begin th chip arround the score.
eibargum
If its a 200 could it be taken out to 70mm [225].
Your best bet would be to sent it back to Tino for welding and replacing. You"ll get it back with a new piston for not much more than the cost of a new piston from Camlam
des
coaster wrote:Your best bet would be to sent it back to Tino for welding and replacing. You"ll get it back with a new piston for not much more than the cost of a new piston from Camlam
Has anyone sent barrells to Tino, what was the turn around time like and cost.
Talk to Shocky. I think he's had some experience with this. If you don't want to go that route then he can certainly put you on to a company in Gloucester that can replate the cylinder. I think there is also a company in Weston Super Mare that does it as well.
rocho68
Pj engineering , west mids , sleeved or replate about £110
paulmgreen
Langcourt are the best for this type of thing. They will weld it back, rebore and recoat - the coatings they use are probably better than original.
Many of the BSSO racers use Langcourt.... so you can rest assured quality wise.
www.JPPLambretta.co.uk
i used langcourt for my ktm barrel ,greatb service and quality
Not personally but he did quote me £90 plus shipping it back to (I think it was about (£10)to sort mine out and was including a new piston for that. I dare say the price will have gone up due to the vakue of the Euro going up (it's comming back down at the moment though). At the time Lancourt would have been about the same as now, around £120 if I
remember correctly but I would have needed to buy a new piston :roll:
I did hear a while back that Tino had taken 3 months to turn one round but I heard more recently (can't remember who said it) that he'd recently done one in about 6 weeks.
The damage to mine was a gouge about 10mm across going from the top down to the exhaust port caused by the debris from a blown piston. Camlam said I could TRY using some wet & dry to smooth out the edges. I did what they suggested and stuck a new piston in it. That one when about 2k miles later and the current one has been on for about 3k miles and has just done the C2C. Not sure about your damage though, imm sounds quite deep :?
    Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 2 guests
