uses 125/150 casingsRICSPEED wrote:i think i want one :bouncing:
did you use 150 or 200 case ???
step by step watercooled lambretta kdx220 setup
i suppose a custom mag and build up the gasket face is one way round milling into the transfer if your mounting the pump there
- twin peeks
- Main scooter: gp200 ts1
ca u still get the crank in when the plate is welded on ,i had aload of bother on my ktm barrelled motor with along rod u need lots more clearance tack it and try it ,i would make the plate bolt on ,looks lovely job tho
love all these engine upgrades
- carlos fandango
Loving it Rocho
Will you be using that af crank
hi carlos , the cranks a maz that paul at pjs done for me but told me it didnt need welding as its to factory tolerances but i might just tig it anyway , what you think ?????????carlos fandango wrote:Loving it Rocho![]()
- carlos fandango
Ohrocho68 wrote:hi carlos , the cranks a maz that paul at pjs done for me but told me it didnt need welding as its to factory tolerances but i might just tig it anyway , what you think ?????????carlos fandango wrote:Loving it Rocho![]()
This is one of the things ive been wondering about? its probably obvious
Q. Why are crank pins just an interference fit ? Why dont they have a spline or keyway or something?
The only thing i can think of, is its simple and easy to true up?
Perhaps i should start another thread and not hijack yours
Russ
- guygrrr
- Main scooter: 1980 Vespa P187
boy, this is really coming together.
what's the spec on the crank yr using? stroke and rod? how much material did you mill off the case? what are you planning on doing with the frame to account for clearance for the carb?
keep up the good work, this is great!
more can do, less doodoo.
The stroke is 58mm with a 110 yam rod ....
This was mine I did yonks ago......never got round to finishing it. Everynow and again it gets dragged out measured up and....well thats about it!!
Decided to use a packer setup to adjust the port times as I need'em. The picture above needs another packer its just bolted together for a pic. The packer will put the reed just far enough away from the engine mount bolt, although frame mods are required for the inlet.......whats ya plans re the frame on yours pal?
