Poorly px125
Yes dazza :D
Oh and can people put a space after the P as I keep wondering what a prange is
Dazza
Where is the inner seal then? Is it part of the bearing?
Is the outer seal - now it's replaced - going to stop the oil or is the fact that it's a secondary seal mean it's going to leak?
I don't honestly know cos iv never had a vespa motor apart ,I just recall reading that the hole is to drain oil should the seal go so I would expect there to be two seals
Dazza
There is an outer seal that as I say has been replaced , which I believe all there was before the efl range so I'm assuming it should be up to the job on it's own?
