LAMBY ENGINE GOT THE ELITE TREATMENT
stafford
BEFORE
DURING
AFTER
Looks lovely, was it expensive and where did you get it done?
Why didn't you take the mounts off?
coaster wrote:Looks lovely, was it expensive and where did you get it done?
Rube (Stafford) has his own powder coating and paint finish company called Elite Refinishing..
ELITE REFINISHING
ADDRESS IS UNIT 10 BOROUGH ROAD INDUSTRIAL ESTATE
DARLINGTON
CO DURHAM
DL1 1TF
TELEPHONE 07791622279
http://scooterotica.org/forum/viewtopic.php?f=12&t=6558
good they masked off properly my powder coater coated everything ........took hours tp remove to get the mag to fit :evil:
DMC
Muttley McLadd wrote:Why didn't you take the mounts off?
yep, more fooked engine mounts. the rubber just loves that heat!
stafford
they were taken out and repressed back in, they are painted,the remainder is powder coat and the rubber does with stand the heat, no probs with all 7 mine
You will be needing some touch up on the casing gasket face area where the cable adjuster block and swivel sit :geek:
    Users browsing this forum: No registered users and 23 guests
